It is currently Tue May 20, 2025 10:43 am
PostPosted: Thu Dec 08, 2005 7:48 am
I am looking for a wholesale seller of a 10/32 allen head truss rod nut that is
about 3/4" long. I have been unable to locate this from MSC, etc. although I
may be looking in the wrong place. LMI has what I want at $3.55 each but I
want 100 at a time and $3.55+ each is just too pricey for me! Can anybody
help?
Sylvan
http://www.wellsguitars.com
PostPosted: Thu Dec 08, 2005 7:54 am
Sylvan, Stew Mac sells them for $2.38 each after 12 units.
Here
Rod True38694.6641550926
PostPosted: Thu Dec 08, 2005 8:02 am
Thanks Rod!
Sylvan
PostPosted: Thu Dec 08, 2005 9:14 am
Sylvan,
I sell some that are custom made. They are a bit shorter at 5/8 inch but are 10/32 thread and use a 3/16 hex key. If you were buying 100 I could sell for the same as Stew Mac, well maybe a couple cents cheaper at $2.35 and it includes a nice brass washer. Here is a picture of the nut and of it on a rod with a hex key inserted.
Hope this gives you another useful option.
PostPosted: Thu Dec 08, 2005 9:35 am
Shane -
Thanks for the option. Let me think about it!
Sylvan
PostPosted: Thu Dec 08, 2005 9:43 am
You bet, just e-mail or PM me if you think you want some. They are quite nice! I think that the allen key is bit larger on these ones compared to the Stew Mac ones, that helps out also.
PostPosted: Thu Dec 08, 2005 10:11 am
First name: Frank
Last Name: Ford
City: Palo Alto
Zip/Postal Code: 94301
Sylvan -
I make 10-32 brass nuts, from either 1/4 or 5/16 hex stock, like a
traditional Gibson or Taylor would use. Could make you some - hit me with
an e-mail. . .
Cheers,
Frank Ford
FRETS.COM
HomeShopTech
FRETS.NET
PostPosted: Thu Dec 08, 2005 10:42 am
Come on guys, can't we get Frank Ford's "Forum Newbie" tag upgraded to
something more appropriate?
Sylvan
PostPosted: Thu Dec 08, 2005 10:50 am
Maybe something like "Ultra Grizzled Veteran"
PostPosted: Thu Dec 08, 2005 11:20 am
Now if he were from the south, that might sound about right Tracy.
PostPosted: Thu Dec 08, 2005 11:31 am
Ya and help him and Tracy get their "www" live like you helped me out.
PostPosted: Thu Dec 08, 2005 7:31 pm
Oh, yeah. Bump him up a notch to "groupie." I'm sure he'll appreciate the
honor.
PostPosted: Fri Dec 09, 2005 12:46 am
perhaps there should be an honorary categoy of "guru"!!!!
certainly for those like me who do a lot of repair work he, dan erlewine, don teeter, etc are of that status!crazymanmichael38695.3675
PostPosted: Fri Dec 09, 2005 1:44 am
I still like, "Exalted and Revered Grand Poobah"!
PostPosted: Fri Dec 09, 2005 3:59 am
But what kind of example does it set to cut in front of the line.
PostPosted: Fri Dec 09, 2005 6:29 am
Yeah, but Frank's always been at the front of the line...the rest of us just didn't see him from so far back!
PostPosted: Fri Dec 09, 2005 7:32 am
Sylvan,
A couple of years ago I got some 10 X 32 1/4" hex nuts online.I forget the name of the company, but they sent me a dozen for samples. If you Google "Hex Standoff Spacers" you will get all kinds of choices. Hope this helps.
PostPosted: Fri Dec 09, 2005 9:16 am
Jimmy -
Thanks for the thought but the truss rod design I want to try with my
instruments mandates that it be adjusted with an allen wrench. The spacers I
think you are talking about would work great if I could get a wrench on them
to adjust but I cannot. An allen wrench through a hole in the transverse
brace is all I've got to work with!
Sylvan
PostPosted: Fri Dec 09, 2005 10:10 am
Gotcha! After I reread your post, I saw that you needed one you could use an allen wrench on.Jimmie D38695.7593287037
cron
